ABS INOP light on after dyno
Old May 18, 2015 | 11:22 AM
pologreen97z's Avatar
Good morning all-
I did a dyno about 6 months ago and immediately afterwards, my ABS INOP light came on and has been on since. I have since had the opti/waterpump replaced so the battery was disconnected which I would have thought would clear it.
Any thoughts on why and how to clear it?
This is a '97 LTI M6.
Old May 18, 2015 | 02:14 PM
Re: ABS INOP light on after dyno
The usual cause for this is the rear wheel speed sensor connection was disturbed or disconnected when they tied down the rear end on the dyno. You should get under and take a look.
Old May 18, 2015 | 02:17 PM
A dealer can scan the electronic brake control module (EBCM) for codes, using a Tech 1 or 2, or a decent brake shop should be able to read it with a Snap-On or similar brake system scanner. A lot of possibilities, making guessing relatively non-productive. But, check the center high mounted brake light (CHMSL) for a burned out bulb.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
