A4? M5?
Old Jan 9, 2006 | 06:52 PM
prisoncitychevy's Avatar
A4? M5?
I see all this and I have no clue what it means. Can anyone help out a little bit?
Old Jan 9, 2006 | 06:59 PM
StephenDeli22's Avatar
Re: A4? M5?
A4 = 4-Speed Automatic
M5 = 5-Speed Manual
Old Jan 9, 2006 | 07:00 PM
Re: A4? M5?
ah, well thats real simple. Thanks.
Bert02SS
Guest
Posts: n/a
Re: A4? M5?
You will see "M6" in my sig. I have the 6-speed Manual trans. Can you guess what "A4" might stand for? (Hint: It's not an Audi.)
Old Jan 10, 2006 | 09:14 AM
2000slp2768's Avatar
Re: A4? M5?
is there a thread that explains all the abbreviations used here? some I can figure out others IE NBM, I dont get.
Old Jan 10, 2006 | 09:16 AM
JakeRobb's Avatar
Super Moderator
Re: A4? M5?
NBM = Navy Blue Metallic, i.e. the color of my car.
Incidentally, many ricers use NBM to mean "nothing but motor", i.e. no boost and no nitrous.
Old Jan 10, 2006 | 09:17 AM
JakeRobb's Avatar
Super Moderator
Re: A4? M5?
Some other colors we usually abbreviate:
SOM = Sunset Orange Metallic
HO = Hugger Orange
Old Jan 10, 2006 | 11:16 AM
MyShibbyZ28's Avatar
Re: A4? M5?
BR = Bright Red
What does IIRC stand for? That's one I can't figure out.
Old Jan 10, 2006 | 11:25 AM
moparman's Avatar
Re: A4? M5?
IIRC= If I Recall Correctly
Old Jan 10, 2006 | 11:40 AM
teke184's Avatar
Re: A4? M5?
ttiwwop - this thread is worthless without pics
hp - horsepower
rwhp - rear wheel horsepower, what is typically measured on a chassis dyno
TA - trans am
IROC - italian retard out cruising
1LE - option code for upgraded suspension in 3rd and 4th gens
Old Jan 10, 2006 | 02:10 PM
Re: A4? M5?
B4C = "cop car" edition of Z28's. Very cool to have!
PITA = Pain In The Arsch
TTT= To The Top
LCA = Lower Control Arms
PHR/PHB = Panhard Rod/Bar
PDR = Paintless Dent Removal
Old Jan 10, 2006 | 02:39 PM
JakeRobb's Avatar
Super Moderator
Re: A4? M5?
BFH: Big F**kin Hammer
TA: Torque Arm (part of the rear end suspension) or Trans Am.
IIRC: If I Remember (or sometimes Recall) Correctly
STB: Strut Tower Brace
TTIWWOP: sometimes written "Titty wop" (see previous post)
RPO Codes: Replacement Parts Ordering Codes - the three-digit codes on a sticker on the back of your driver side door, indicating the original options included on your car.
ODB: On-board diagnostics. 1995 and earlier cars are equipped with OBD1, and 1996 and newer cars are equipped with OBD2, which adds a lot of emissions diagnostic ability and makes modifications much more likely to cause an SES
SES: Service Engine Soon - indicator on gauge cluster. Take your car to AutoZone and they will tell you what the problem is, for free.
CEL: Check Engine Light - indicator on gauge cluster.
Old Jan 10, 2006 | 02:41 PM
JakeRobb's Avatar
Super Moderator
Re: A4? M5?
LT = Long tubes, a type of exhaust header known for excellent flow and power gains.
"Shorties" = short tube headers. Depending on the car, these may or may not improve performance.
CAGS = Computer Assisted Gear Selection -- mode on six-speed 4th-gens (and most other GM cars with the 6-speed manual) which prevents you from shifting into 2nd or 3rd under certain conditions in order to improve gas mileage.
SFC = subframe connectors
Old Jan 10, 2006 | 02:43 PM
JakeRobb's Avatar
Super Moderator
Re: A4? M5?
FRA: Free Ram Air -- a free mod that adds a sort of ram air to your air intake.
SSRA: Super Sucker Ram Air -- a non-free mod that does pretty much the same thing, only different
Want any more?
Old Jan 10, 2006 | 05:13 PM
93black-ta's Avatar
Re: A4? M5?
did someone do:
N/A - natrually aspirated
