A4 car won't shift out of park after sitting...not trans, it's the shifter
Just a thought for those that disconnected the solenoid and still having probs. I had a hard time getting mine to shift from park and I also have had extremely hard second gear shifts for some time. I ordered a new trans mount and just replaced it today. When I got under the car, I was surprised to see a poly bushing in there! Replaced it and not only does it shift much better, it goes from P to D much better now. What I figured was that the poly bushing sits a little lower in profile than the new one. I had to jack up the trans to get the brace bolted up. I think that the trans is sagging a little making it hard to shift from Park. Maybe I am off, but it fixed my problems for sure.
Jim
Jim
I'm having the exact same problem with my 95Z. I disconnected the BTSI solenoid and now there are no problems. Does anyone know how much it would cost to replace this part? If it's really not necessary, or if it wont set a SES code, I'll probably just leave it disconnected.
Re: A4 car won't shift out of park after sitting...not trans, it's the shifter
I was able to loosen the console plate over the shifter just a couple inches, it seems to be hung up on the front part of the plate. I was able to lift up the ashtray some and saw the exact thing as the picture in the 4th post of this thread. Where is the plug-in that you unplug. Is it in that picture on the fourth post?
Thanks, my cars been sitting for over a year with this problem.
Thanks for the info guys....I just spent 10 mins trying to get my '95 Z outa park. I will try that removing ashtray & lifting cable tomorrow & see if it works.
Worked like a charm. I just lifted ashtray out, touched that black cable thing & the shift button went right in. Thanks guys!
Shoebox...your site rocks!
