97 Z28 Vat Issues
Old Oct 14, 2010 | 02:35 PM
chevymae's Avatar
Question 97 Z28 Vat Issues
I have a 97 z28 with a tore up ignition and a broken key with missing pellets. I can turn the ignition over with a screwdriver but it wont crank. I would like to just bypass the vat system with the resistor solution but their are 15 different combos and without the key to know which to use im not sure where to begin. Im trying to avoid making all 15, is there a place i can buy them online already put together? I obviously dont know very much about this so any info would be helpful.
Old Oct 14, 2010 | 03:01 PM
You could use a potentiometer to try to "dial-in" the resistance value.
http://shbox.com/1/pass_key.html
Old Oct 15, 2010 | 12:03 PM
deereman79's Avatar
just got done with this ordeal, does it turn over as engine turns over but wont start or does the switch just turnover and no sounds at all?
Old Oct 15, 2010 | 04:33 PM
chevymae's Avatar
i turn the ignition over an the security light blinks but nothing else, it doesnt fire.
Old Oct 18, 2010 | 04:53 PM
deereman79's Avatar
find the theft deterrant relay under the right hand dash. shbox has a good pisc of this on his sight. take the relay out and put a jumper wire from the yellow to the purple and see what happens, if it turns over them go from there. finally got mine running and it still has the jumper wire is still in there know it will stay permantly.
Old Oct 22, 2010 | 01:18 PM
chevymae's Avatar
ok i bought the resistors online and none of them shut the security light off. The security light blinks when i turn the ignition to the on position but only the first time i turn the key, after that it no longer blinks just stays on no matter how many times i turn the key. After about maybe 7 or 8 mins the security light shuts off but it still wont fire. Im not sure where the TDR is located or if its the problem, underneath the glovebox? Any suggestions would be helpful thanks.
Old Oct 22, 2010 | 03:05 PM
GRIDERMAN87's Avatar
after multiple failures the system will shut down for around 15min to 1 hour, your vats system is under your kick panel, there will be a thin orange wire that meets with another (i think its white) you can bypass the entire system there are several write ups on the net. First you have to find the right resistor pellet, you might call GM to find out which one you need. After that i would recommend finding a shop that can do the bypass your local dealer may know of one, this is a fairly common issue, usually costs around 150.00 but after that your vats system will always read that the correct key is in place i can post pics of mine if you would like
Old Oct 22, 2010 | 05:09 PM
Or D-I-Y using Shoebox's instructions........
http://shbox.com/1/vats_bypass.jpg
Old Oct 22, 2010 | 07:02 PM
chevymae's Avatar
Ya thanks guys but i tried all 15 resistors and it didnt solve anything.
Old Oct 25, 2010 | 09:25 AM
if you tried it through the ignition it wont work if the wire has broken in the dash somewhere leading into the ignition switch, you have to bypass further down in the system
Old Oct 26, 2010 | 09:59 AM
deereman79's Avatar
the tdr is a black or grey square cube relay under the right hand side up behind the glove box, mine was clipped on underneath to a metal strap holding it up. right beside it is a silver box which i think is air bag....
unplug the relay and take a peice of wire and jump from the yellow to the purple wire and see what happens. mine was doing that and it workes.. the yellow wire is coming from ignition and the purple is the solonoid wire jumping them together should send power to the starter through the ignition
Old Oct 26, 2010 | 05:07 PM
chevymae's Avatar
right on thanks ill give it a try
Z28countrymama
Jan 22, 2015 02:50 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
