97 LT1 help needed
Old Nov 13, 2013 | 08:06 PM
burntorange's Avatar
97 LT1 help needed
i have a 97 Camaro lt1 6spd about a week ago the car got a stumble in it but would ony stumble once or so and run fine the Monday as I was leaving work it dies at stop sign cranked few times fires up and runs great. well next morning same thing dies and fires up runs fine now the car has got hard to start smells flooded and tach jumps around bad, tried to scan and scan tool wont connect to car any ideas? im not a chevy guy so im lost any help would be great.
Old Nov 14, 2013 | 05:19 AM
Re: 97 LT1 help needed
If an OBD-2 scan tool won't connect, check the fuse for the cigarette lighter - that's what supplies 12V power to the ALDL connector.
Old Nov 14, 2013 | 08:59 PM
fuses are all fine
Old Nov 15, 2013 | 09:06 AM
What scan tool did you use?
Old Nov 15, 2013 | 06:38 PM
solus pro I put a icm on car it runs now but tach stil jumps around
Old Nov 16, 2013 | 08:28 AM
Tach is driven off the PCM, based on the cam position signals from the Opti. If the high resolution pulse patter is going erratic, might cause the tach to jump around. The high res pulse signal won't set a code unless it totally disappears for 10 crank revolutions.
Might be worth checking the harness connector at the Opti, for corrosion or a bent pin.
I'd try another scanner. There are $25 cheapies that will pull the codes. If that shows no connection, the wiring for the ALDL connector needs to be checked. Did you verify you have 12V on pin 16?
Old Nov 16, 2013 | 10:03 AM
its powering scanner just wont read or comm. with car we tried cheap one as well
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jrlt1
Jan 3, 2015 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
