96Z fuel pump/sending unit replace
Old Jul 20, 2006 | 01:10 PM
cleangene's Avatar
Ok, guys tell me if you have to drop the muffer in order to drop fuel tank for replacement of the fuel pump/sending unit on a 96Z, I don't have the tools for cutting and rewielding the pipes, It the muffer has to come out then I have to take to some one else and pay the labor.
Thanks Clean Old-School
Old Jul 20, 2006 | 01:13 PM
Bow94z's Avatar
Re: 96Z fuel pump/sending unit replace
to replace a fuel pump on these cars the muffler/rear need to be dropped to drop the gas tank..
although many have gone the "trap door" route were you cut a hole in the trunk to access the fuel pump...alot of people do it this way
http://home.comcast.net/~fastbird/Tr...%20Install.htm
http://www.worldisround.com/articles/12533/index.html
http://www.geocities.com/formulapower2/fuelpump.html
http://www.taekwondoplus.org/z28/fuelpump.html
Old Jul 20, 2006 | 01:14 PM
Makaveli's Avatar
yes i believe the muffler needs to removed in order to have enough space to drop the tank, atleast last time i looked under there, the muffler was included in my tally of things to remove to drop the tank.
your other option is the trapdoor method, cutting a hole from inside the car to access the fuel pump. do a search in this forum for fuel pump replacement or trapdoor method and that will give you all the information you need.
Old Jul 20, 2006 | 01:28 PM
FastZinTennessee's Avatar
Exhaust/rear end has to drop in order to get the gas tank out. May god have mercy on your sould.
Old Jul 20, 2006 | 02:01 PM
Sweetred95ta's Avatar
I've HEARD that the filler neck is a big PITA. Just a heads up. I did the trap door and I thank god everyday that I did it that way. I can have my pump assembly out in about 10 min. If you rig your bucket for a Walbro, like I did, it comes in handy to fix little mistakes you may have made. Just my .02.
Old Jul 20, 2006 | 04:00 PM
cleangene's Avatar
thanks for answering, just checked with a friend at the shop that did my tranie, they want over $300 in labor, I am going with the door for sure...
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ANDYZ28
Dec 29, 2014 09:13 PM
isimplyexist
Mar 25, 2004 08:06 PM
