96 Z28 Accessory plug?
Old Nov 22, 2007 | 03:08 PM
Lee96Z28's Avatar
Question 96 Z28 Accessory plug?
I'm trying to adapt a traction control reversal module (not SLP's) to my 96 Z28. It requires 12v power when the key is on. Under my console, there is part of the wiring harness that comes from under the dash that is marked "Accessory Plug. See Owner's Manual" (or something close to that). There is no plug nearby. There are 3 wires: pink, orange and black. This part of the harness is folded over and taped to all of the other wires. In the owners manual it tells you what each wire is and talks about using them to connect a CB radio or similar devices and that the connector is located in the front part of the console ahead of the shifter. This is not the case. It is NOT the cigarette lighter. Those wires are separate and the cigarette lighter always has power, not just when the key is on.
Anybody have any luck finding this accessory plug? I would rather use this plug if it exists, rather than tearing into my wiring harness.
Thank for any input.
Lee
1996 Z28 M6
Old Nov 23, 2007 | 07:40 AM
4THGEN Z's Avatar
There is no actual plug....you would tie into the wires you found under the console....I used them for my e-cutout.
Old Nov 25, 2007 | 01:21 PM
Lee96Z28's Avatar
Thanks! That's what I'll do. I just didn't want to tear into it without asking the question first.
Lee
96 Z28 M6
F'n1996Z28SS
Aug 23, 2023 11:19 PM
siguy
Nov 27, 2014 10:07 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
CobraEatr
Jul 23, 2002 06:32 PM
