95 LT1 PCM internals
Old Aug 27, 2022 | 03:09 PM
Calebs83z28's Avatar
I have a PCM from a 95 5.7 LT1 16188051 with a burned capacitor. I am looking for someone who has a junk or at least opened PCM who could tell me the size of the capacitor as mine is completely blackened. I am just looking for the numbers on this device. This is the disk shaped capacitor between the black and red connectors, there are 2 side by side the one I need is closest to the black connector. I have a picture if needed.
Old Aug 30, 2022 | 09:39 PM
Re: 95 LT1 PCM internals
Update: I did find out this component is a MOV (surge suppressor) between Battery + and sensor ground, black connector pins 15 & 16. So the specs aren't critical, I just need to get the correct voltage rating, I am guessing 15 to 20 volts. I removed it and now the resistance from pin 15 to 16 is over 1K instead of 6ohms, so I am hoping this is my only issue. I will update as soon as I get a new one installed.
Old Sep 18, 2022 | 08:38 PM
It looks like the MOV was the issue. Its back on the road again.
Old Sep 24, 2022 | 11:22 PM
GaryDoug's Avatar
Prominent Member
You are right....EE here ;-) I would wonder what caused the surge suppressor to fail. Bad alternator voltage regulator? The suppressor was obviously shorted.
97 6SPEED Z
Aug 25, 2021 09:00 AM
LT-7
Mar 23, 2006 08:54 PM
Hardee46360
Parts Wanted
May 1, 2005 04:47 PM
95LT1TA
Parts Wanted
Mar 23, 2005 09:21 PM
MadMax350
Jan 27, 2004 03:42 AM
