95 lt1 with 700r4
Old Apr 27, 2015 | 02:13 PM
jimmybandana's Avatar
95 lt1 with 700r4
Ok so I already have the 93 throttle body, what bracket and throttle cable will I need? I'm ready to drive this thing! Thanks for the help.
Old Apr 27, 2015 | 04:15 PM
Re: 95 lt1 with 700r4
Shoebox has the info you need.... always a good site to start your search:
http://shbox.com/1/tv_cable.jpg
Old Apr 27, 2015 | 05:48 PM
I can't find where it says what bracket or cable that is needed?
Old Apr 27, 2015 | 06:07 PM
The diagram I linked shows the GM part numbers for the TV cable (which includes the trans bracket), o-rings, and the bolt for the bracket.
Old Apr 27, 2015 | 06:10 PM
So tv cable is the run that runs to the gas pedal correct?
Old Apr 27, 2015 | 06:15 PM
No, connects to a stud on the side of the 93 throttle body quadrant. Throttle cable from pedal to the throttle body is the same for all years, except models with traction control.
Old Apr 27, 2015 | 06:24 PM
Old Apr 28, 2015 | 08:52 AM
That isn't where the TV cable for the trans connects. That's where the accel pedal cable connects. Should have a small metal cylinder on the end, that slides into the hole in the side of the quadrant.
Your 93 throttle body quadrant should have 3 connections:
1 - the cable from the accel pedal, that connects where you are trying to connect the cable in your photo. As noted, the cable has a metal cylinder that slides into the hole in the side of the quadrant, then you align the cable in the groove in the quadrant.
2 - the cruise control cable. Both the accel pedal cable and the cruise control cable mount in the bracket on the side of the manifold. The cruise control cable has a black plastic clip on the end that slips over the stud connection on the arm pointing down in your picture.
3 - the TV cable. Has a black plastic clip on it, just like the cruise control cable, and slips over a similar stud on an arm that stick up, and is not in your picture. It's that arm, pointing upward that is only on the 1993 throttle body.
The plastic clip on the end of the TV cable, and the arm it attaches to is shown in "View A".
Old Apr 28, 2015 | 09:01 AM
From 1993 factory manual:
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
