94 z28 headlight issue
Old Aug 1, 2017 | 06:55 PM
Knuckles1260's Avatar
I have no headlights on my 94 i just got it so i dont know a whole lot about it ive got all my other lights they work fine. I dont have high or lows and ive check my fuses just wanting to know if there is a place i need to be starting before i go off on a wild goose chase
Old Aug 1, 2017 | 08:11 PM
Re: 94 z28 headlight issue
"Car Audio.... " isn't the best forum for this topic. Let's move it to "General 67-02 F-Body Tech".
This diagram (94 should be similar to 95) indicates the headlights get power via a fusible link (at the red plastic + box near the battery), and then there is a circuit breaker integral with the headlight switch. Check for 12 volts on the red wire (pin J) at the headlight switch to check the fusible link. Turn switch to "headlights" and check for 12 volts at the yellow wire (pin E) to check the circuit breaker).
Courtesy of Shoebox:
http://shbox.com/1/headlight_chevy_1995.jpg
