94 Z28 Emissions
Old Mar 27, 2009 | 02:31 PM
tps07's Avatar
94 Z28 Emissions
My emission results for 94 Z28. Any recommendations would be appreciated.
Engine has 215k. Has edelbrock headers, slp exhaust from a 97 Camaro (2 cats). Just changed optispark/water pump. Hypertech has been used.
ASM2525 Test
Limit / Reading
HC 55 122 Fail
CO% 0.31 1.57 Fail
NO 408 756 Fail
RPM 1875
Dilution 14.9
Curb Idle
Limit / Reading
HC 200 175 Pass
CO% 1.00 3.15 Fail
NO N/A N/A
RPM 808
Dilution 15.3
Old Mar 27, 2009 | 06:59 PM
The fact that HC, CO and NOx are all high under load would seem to indicate a problem with the cat. High HC and CO might mean its running rich, but the NOx would be low in that case. High NOx can indicate a high combustion chamber temp, or running lean. But with high HC and CO that doesn't seem to be the case.
Old Mar 29, 2009 | 08:01 PM
tps07's Avatar
Thx for the reply.
Why would the HC pass during the Idle test while still failing the CO?
Jason Short
Jan 19, 2015 06:34 PM
Jan 5, 2015 07:14 PM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
Queens94z28
Nov 20, 2014 06:03 PM
