94 formula AC question, for the electrical pros
Old Dec 29, 2019 | 12:43 PM
Darrenmb's Avatar
Hi folks, I have tried searching, here and and Google, alas nothing concrete to be found..
what I have is the entire drivetrain from a 94 formula, along with all ancillaries, it is going into a 1983 jag xj6,, the mechanical side of things should be a breeze, however no matter how many schematics I look at, I cannot figure out the ac system, all I need is compressor and fans to.work, as everything else is jag controlled,
can someone tell me if this is possible? I am seeing pressure sensors, and evap coils sensors, etc, can they be bypassed or ignored? Any helpmwould be greatly appreciated.
If more info is needed, please let me know, I am using the jag evap and condenser, hoping to just have new lines made up..
thanks
Darren
Old Dec 29, 2019 | 03:39 PM
Re: 94 formula AC question, for the electrical pros
The PCM controls the compressor clutch, based on inputs from the HVAC control assembly, the refrigerant pressure sensor, and the evaporator temperature sensor. It's shown in the PCM wiring diagram:
http://shbox.com/1/1995_pcm5.jpg
Have you reviewed that diagram?
Additional info is contained in the 1994 factory service manual, free download here:
https://www.mediafire.com/?40mfgeoe4ctti
You would have to interface the Jag's A/C control switch with the PCM, insert the 94 temp sensor into the Jag's evaporated coil, and incorporate the pressure switch in the correct location in the Jag's plumbing.
Factory wiring harness:
http://shbox.com/1/harness.htm
94 and 95 are identical in this area.
Old Dec 29, 2019 | 03:47 PM
Darrenmb's Avatar
Hi,
thanks for the reply, yes I have that page printed, along with tons of others from.shoebox and lt1swap, I guess I need to find out of I can use the jag 12 volt.signal and use it to engage clutch and activate fan relays, am I correct in assuming that if I do that, the idle will will be adjusted by pcm without input?
Old Dec 29, 2019 | 03:48 PM
The A/C control switch wire connects to connector C230. Connector pinouts - note tabs at bottom for each connector:
http://shbox.com/1/harness_connector_faces.htm
Old Dec 29, 2019 | 03:56 PM
Darrenmb's Avatar
I currently have that connector on my dining room table ( much to my wife's dismay) previous owner completely hacked up the fuse block it attaches to, thank you for that link. I still.havent put engine in the jag yet, but trying to make everything as easy as possible.once it's in place.
Old Dec 29, 2019 | 03:58 PM
You don’t activate the clutch directly. The A/C control switch tells the PCM the A/C has been requested. If the required conditions are met, the PCM actuates the clutch relay.
The PCM activates the coolant fans based on input from the coolant temp sensor in the water pump housing. 94 fan controls can be either 2 relays (early production 1994) or 3 relays (late production 1994):
http://shbox.com/1/1995_pcm6.jpg
Old Dec 30, 2019 | 07:12 AM
Darrenmb's Avatar
Sorry, internet went down...
I guess my next question then is can pcm be tricked iinto thinking that those sensors are there? As access to evap on jag is a 3 day job!!
Old Dec 30, 2019 | 08:10 AM
Have no idea.... I deleted my A/C 20 years ago.
Old Dec 30, 2019 | 10:00 AM
Darrenmb's Avatar
Ok, thanks
bobdec
Jun 14, 2014 09:29 AM
94droptopz
Parts Wanted
May 19, 2005 01:50 PM
kyzar24
Jul 4, 2004 06:02 PM
DR.ZED
Aug 13, 2003 07:31 AM
