'93 Z28 E brake light and ABS light on
Old Dec 27, 2010 | 11:18 PM
krsillivan's Avatar
My son just bought a '93 Z28. The emergency brake cable was broke. The emergency brake light and the ABS light were on when he bought the car. I replaced the emergency brake cable, and both lights are still on. I thinking that the ABS system is bad and thats why the ABS light is on. Why would the E brake light stay on, could it be a bad sensor or is the ABS causing this? Any help would be appreciated. Thanks
Old Dec 28, 2010 | 07:29 AM
Re: '93 Z28 E brake light and ABS light on
The "BRAKE" light comes on for two reasons 1) e-brake is on; 2) the switch on the side of the ABS unit, where the two lines from the master cylinder connect, indicates a difference in hydraulic pressure between the front and rear braking lines. Could be low fluid, air in a line, or a leak. I suspect that once the "BRAKE" light comes on, the ABS will not work, but I don't know that for sure.
The brakes need to be checked for fluid level, or other problems.
Old Dec 28, 2010 | 10:17 AM
krsillivan's Avatar
The brake master cylinder is full. I"ll bleed the brakes and I"ll check the switch to see if it's working. Thanks
Old Dec 28, 2010 | 10:19 AM
krsillivan's Avatar
The master cylinder is full of fluid. I'll bleed the brakes, and check to see if the switch is working. Thanks
Old Dec 28, 2010 | 12:05 PM
The differential pressure switch can get stuck. Those of us with line locks in the front braking system run into the problem once in a while. The solution is to get it in an open parking lot, and do a really hard stop. That will usually release a stuck switch.
But if you don't have a line lock, the question would be why did the switch get stuck.
Old Dec 28, 2010 | 09:46 PM
krsillivan's Avatar
I tried stomping on the brakes 4 or 5 times while parked in the driveway, I'll try it in a parking lot next. I replaced the E brake sensor, but the E brake light is still on. When you turn the car off and then restart it, the E brake light and the ABS inop light do not come on, but then when you drive about 10 feet they both come on at the same time. I tried to use my code reader on it but it's not flashing a code.
Old Dec 28, 2010 | 10:36 PM
You need a high-end scanner to read the EBCM system. Can't do it with a PCM scanner. The "BRAKE" light is indicating you have a pressure problem. Might want to have a pro look at it.
Old Dec 29, 2010 | 10:35 PM
krsillivan's Avatar
I'll have my son take it in and have it checked out. Thanks for your help. I appreciate it.
Old Jan 1, 2011 | 11:59 PM
Fatdog2's Avatar
I don't know about the emergency light,but I had the brake light switch replaced(under the dash)and that fixed my abs problem.(Just a note)If your third brake light is out,or the wrong wattage bulb,the abs will come on.It's all onthe same wiring diagram.Hope this helps.
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
ddr698
Jan 9, 2015 10:05 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
fpete1992
Dec 11, 2014 03:51 PM
