93 trans am instrument cluster, what years will work?
I'm guessing this is a one off year for the cluster like alot of things. Basically it had a white face and it was trash, pulled it off and the temp/fuel guages dont work now. Cars sold and new owner is coming sat. The place I deal with I called and called, never told me if they had one, so time to check the other yards, but before I do, need to know which years will work.
Also can u replace just the fuel/temp guages? If so will the ones from a firebird or newer ta clusterr work? The guys gotta drive 200+ miles back home, so definetly want him to have a fuel guage!
Re: 93 trans am instrument cluster, what years will work?
I bet that when you removed the white face you may of pulled out on those two needles. push them back in and they should work again.
The needles sit on little metal pins. If you pull the pin out, it turns really hard and wont work. Push the pin back in and it turns freely again.
Put your finger on the center of the needle and push it in gently, then test it.
I did get the fuel guage to work. In think I had the pin itself turned toofar one way. The pin on the temp guage got bent, so I think thats why it wont work now.
I did located some now need to know if 93 is only 93 for the cluster.
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
