92 305 TBI to TPI swap
What all is needed to do this swap??
Also to complicate the matter we're thinking about using an older 2 pcs. rear main 355 with trickflow heads and a healthy cam, and a holley stealth ram intake.
Do the TBI and TPI car's use the same computer?? Do we need a TPI ECM or will a chip change work?? What about the harness?? any sensors interchange between the TPI and TBI??
Thanks for any and all help fellas, this is going in a 5 speed car also just to let you know.
Re: 92 305 TBI to TPI swap
I don't see the Stealth Ram really complicating anything, excepting of course the issue above with the intake manifold bolt angles. I'm sure if you tell them you're using an older engine they can let you know if it will work. This whole bolt angle thing may be a moot point if you're using aftermarket heads.
I don't know about the Stealth Ram, it's something you'll have to research, but I do know that stock TPI intakes choke off an engine that's trying to make more than 300hp. A bigger Throttle Body combined with the Stealth intake may solve this problem as well.
The ECM from the TBI should be the same as the TPI, and a new chip should be all you need. However, you'll probably have to buy a custom chip to handle your upgraded motor.
