454 is in 95 Z-28
Old Feb 17, 2006 | 09:25 AM
cwaldt's Avatar
454 is in 95 Z-28
I got my 454 BBC in my 95 Z yesterday. Of course you can tell by the photo's I went in through the bottom. This payed off really well because I had to lift the car about 4-5 times to do some modifications on my firewall on the drivers side. It wasn't too bad. Only took me about 5 hours and that was having to make room for the bigger motor too. Putting an LT or LS-1 back in this way shouldn't take an hour or so.
Old Feb 17, 2006 | 09:29 AM
OutsiderIROC-Z's Avatar
Re: 454 is in 95 Z-28
I like it!!!!
Old Feb 17, 2006 | 09:31 AM
soul strife's Avatar
Wow! That thing is going to be a beast! Nice work, man.
Old Feb 17, 2006 | 09:35 AM
cwaldt's Avatar
Thanks for the reply's. Putting the 454 in through the bottom was actually easier than when I put an LT-1 in though the top last year.
Old Feb 17, 2006 | 10:41 AM
stingercamaro's Avatar
Very Nice
Old Feb 18, 2006 | 10:23 PM
jm90camaro's Avatar
Awesome. Get some vids once you get it running and drivable .
Old Feb 18, 2006 | 10:52 PM
Honda Hunter's Avatar
Wow. That's going to be cool. My question is once it's installed what normal stuff maitnance wise will you not be able to do anymore because of the position of the motor?
Old Feb 18, 2006 | 11:05 PM
Camarocracy's Avatar
That's sick. I hope you have double-diamond subframes and a 9" rear
Old Feb 18, 2006 | 11:07 PM
NavyBlueFanatic's Avatar
Is this a common swap? How is it going to effect the handleing?
Old Feb 19, 2006 | 09:28 AM
myslowcamaro's Avatar
do you actually have enough room for the intake/carb? looks close
Old Feb 19, 2006 | 09:35 AM
EDS Z28's Avatar
Wow, that's a big motor in there. What are your plans for the exhaust? headers? How is spark plug access?
Old Feb 19, 2006 | 11:31 AM
cwaldt's Avatar
I'm going to have to cut a little for the carb to fit. It''' fit fine but I have to use a low profile air filter. As of right now I can get my hand inbetween the engine and the firewall on both sides. So I don't think anything will be anymore difficult maintance wise than on a LT-LS motor.
I'm probably going to make my own headers. I might try a set of Hooker Headers that are supposed to work but the primaries aren't that big. I'm going to run a 3" x-pipe and bullet mufflers.
Suspension will be worked on after everything else is done. I'm also working on my 9" rear end right now.
Old Feb 19, 2006 | 02:15 PM
Have fun changing the distributor if you ever have to. I think a RamJet fuel injection set-up might fit.
Old Feb 19, 2006 | 04:52 PM
RedHottG2's Avatar
That's SWEET!!
Old Feb 20, 2006 | 10:04 AM
kingslam's Avatar
Dang cwaldt I need to move my shop from the frozen tundra of Wisconsin down to Charolette and you come work with me man! Sweet job!
IndyZman
Oct 22, 2015 02:17 PM
Jake Bialke
Sep 24, 2015 11:31 AM
rvonsternberg
Sep 14, 2015 11:58 AM
cohopefull
Sep 8, 2015 03:22 PM
heus
Sep 8, 2015 12:01 PM
