4.10 gears??
Old Jan 25, 2011 | 02:09 AM
Z28_Cali_Cas's Avatar
4.10 gears??
I was wondering if my 95 z28 will be able to handle 4.10 gears. Its pretty stock as of right now. It just has flows, cold air intake, a new stronger clutch, and it will have a larger throttle body. Its in no way my daily driver so I won't be putting daily stress on the rear end. I'm just starting to modify my Z due to now having a daily driver so any thoughts and suggestions are helpful. Thanks alot
Old Jan 25, 2011 | 05:18 AM
Re: 4.10 gears??
4.10's really wake up the M6 cars. With a basically stock engine, you won't have issues with hitting redline in 4th gear through the traps at the track. 4.10's are probably a bit weaker than a numerically lower gear, so its always an issue with the fragile 7.5" 10-bolt. Just stay away from super sticky tires on a sticky track, and 5,000rpm clutch dumps and you should be fine.
You might want to spend the "larger throttle body" money on something else, because you really aren't going to see any gains from it until you start making some serious breathing changes to the engine.
Old Jan 25, 2011 | 11:38 AM
Re: 4.10 gears??
thanks for the help. I very much doubt I'll ever be bring in my Z to the track so I shouldn't have too much of a problem with the stickyness. Now I already have the throttle body. What suggestions could you give me to get started. Nothing to big just yet so no supercharger or nos. Any pointers are appriciated. This is prety much just my only toy left so I'm ready to start workin on it. I have a couple thousand to start with. Thanks
Z28_Cali_Cas
95 Z28 6speed convertable flows, cold air, 84,xxx miles
Old Jan 25, 2011 | 02:41 PM
jlew69's Avatar
Re: 4.10 gears??
I have a 95 Z M6 with a Lt4 big cam, long tube headers,slp loudmouth 2 w/4.10 gearing, and a cold air kit. It runs very well. With 4.10 gears my car runs about 2500 rpm's at 55 mph in 5th gear, and 2000 rpm's in 6th I still get good mileage. Like you, my car isn't a daily driver. However, it's fun to drive with the above mentioned add on's. I plan to get a tune done this spring to wake it up more. These things are a good starting point. Have fun.
Old Jan 26, 2011 | 02:19 AM
Re: 4.10 gears??
well getting long tubes are kinda out of the question cause I'm out here in Cali. I like the cam idea though. How much would I be looking at to have a cam installed?? Ball park Figure.
Old Jan 26, 2011 | 02:37 PM
jlew69's Avatar
Re: 4.10 gears??
Not sure how much out there in Cali. I installed mine in about 6 hours.
Drtryder
Apr 22, 2015 04:17 PM
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
GRN96WS6
Sep 8, 2002 10:45 PM
funina91ss
Aug 6, 2002 11:20 PM
