3.73 question
3.73 question
hey guys.
my friend has a 3.73 rear end hes gonna sell me, its a 3 channel abs rear end. came off a 96 formula and i have a 97 z28 will that bolt right up? someone said that it wont fit if i have traction control but i dont. someone said i had a 4 channel abs but i thought i had 3channel....got any info on this?
Re: 3.73 question
Originally Posted by RichyZ28
thats what i thought ijust wanted to be 100% sure, thanks pete
.Bill, the difference between an ABS only (3-channel) vs. a traction control car (4-channel) is that the reluctor ring is built onto the carrier of the 3-channel diff, whereas there is a reluctor ring on the end of each axle for a 4-channel setup. The conversion can be made, but it's a bit of work. Just find the one specific to what you need.....it's easier
Re: 3.73 question
Thanks for the info Pete. I have a buddy of mine who has a 94 Formula with a 3.73 rear in it and my 95 Z28 has what I believe is a 3.23 gear and he is willing to swap me straight across, but if I am going to go to the trouble of going into a rear differential, I am going to buy new gears and put them in my housing.
Thanks again for your information. It is much appreciated.
Originally Posted by Capn Pete
No prob
Re: 3.73 question
A 3 Channel ABS rear will work for either car. If you have TCS, you just need to put TCS axles and backing plates on the 3 channel rear and just plug the sensor hole on top of the pumpkin if it's missing.
