2002 Z28 blinker not working
Old Jun 7, 2015 | 10:19 AM
hackman's Avatar
Left turn signal works perfectly.
When I make a right turn, the light comes on solid on the dash but neither front-right nor rear-right turn signals blink.
If I put on the hazards, all four lights blink which makes me think the lights are NOT burned out and it isn't a fuse issue.
My best guess is to tear apart the dash panel on the drivers side to check on the flasher, but thought I'd look for opinions on the forum first to see if there are other things I should check.
Thanks in advance for any help/suggestions!
Old Jun 7, 2015 | 10:31 PM
Fatdog2's Avatar
Re: 2002 Z28 blinker not working
I say burned out light bulb.I think there are two filaments in the bulb,one for emergency,and one for turning left or right.Next the sockets are known to be toast after a while.If both the left and the right signals don't work it's the turn signal flasher under the dash.Hope this helps.(use the correct # bulb for your application.I would do the cheap stuff first.My02.
ANDYZ28
Dec 29, 2014 09:13 PM
Red97LT1
Aug 4, 2002 08:01 PM
dreamer1q
Jul 9, 2002 05:37 PM
FASTFATBOY
Jun 20, 2002 11:27 AM
