2.73 or 3.23 gears???
Re: 2.73 or 3.23 gears???
Look on your driver's side door jamb or in your glove box(should be one of those 2 places) for a sticker with a load of numbers. Look for GUx, which is the rear axle ratio.
GU2 - Axle Ratio 2.73, Rear
GU4 - Axle Ratio 3.08, Rear
GU5 - Axle Ratio 3.23, Rear
GU6 - Axle Ratio 3.42, Rear
Here are some others in case you're interested, for anyone else these are all LS1 codes:
RPO Code List
RPO Production Codes (LS1)
AG1 - Power Adjuster, Driver Front Seat, Multi-Directional
AK5 - Inflatable Restraint System, Driver and Passenger Seat
AQ9 - Front Bucket Seat, Driver and Passenger Recline
AR9 - Front Bucket Seat, Driver and Passenger Recline, European Style
AU0 - Remote Entry Lock Control
AU3 - Side Door Electric Lock Control
AX4 - Restraint Conversion Seat, Manual European
A26 - Window Glazing, European
A31 - Window, Power Operated, All Doors
A90 - Lock Control, Right Component Lid, Remote Control Electronic Release
BAG - Parts Package Export
BBS - **** Shifter Hurst
B35 - Covering Rear Floor Mats
B9W - Wiring Provisions, DRL Override
CC1 - Roof Hatch Removable Panels, Glass
C49 - Rear Window Defogger, Electric
C60 - HVAC System AC Manual Controls, Front
DD9 - Mirror, Breakaway, O/S LH & RH Remote Control Electric Color
DE4 - Sunshade, Removable Hatch Roof
DG7 - Mirror, O/S LH & RH Remote Control Electric Color
DL5 - Decal, Roadside Service Information
DS1 - Sales, Diplomatic
D21 - Sunshade, Windshield
D35 - Mirror, O/S LH Remote Control, RH Manual Control, Color
ETA - Harness, I/P Wiring #1
FE2 - Suspension System, Ride and Handling
FE4 - Suspension System, Special Ride and Handling
FE9 - Certification, Federal Emission
FLT - Fleet Processing Option
F41 - Suspension System, Front and Rear Firm Ride and Handling
G80 - Axle Positraction, Limited Slip
JAF - Brake Provisions, European
J65 - Brake System, Power, Front and Rear Disc
K05 - Heater, Engine Block
K29 - Module Powertrain Control
K34 - Cruise Control, Automatic, Electronic
K43 - Generator, 102 Amp
K68 - Generator, 105 Amp
LS1 - Engine, Gas V8 5.7L SFI Aluminum
L36 - Engine, Gas V6 3.8L MFI HO
MAE - Marketing Area Europe
MM5 - Merchandised Transmission, Manual 5 Speed
MM6 - Transmission, Manual 6 Speed O/D
MN6 - Merchandised Transmission, Manual 6 Speed
MX0 - Merchandised Transmission, Automatic O/D
M30 - Transmission, Auto 4 Speed Electronic
M49 - Transmission, Manual 5 Speed O/D
NA3 - Emission System, Japan
NC1 - Emission System, California
NF7 - Emission System, Federal
NK3 - Steering Wheel, Sport, Soft Rim, Simulated Leather
NM2 - Emission System Export, Leaded Fuel
NP5 - Steering Wheel, Leather Wrapped
NP7 - Steering Column, EEC Approved
NT3 - Emission System, EEC 00
NW9 - Traction Control, Electronic
N36 - Steering Wheel, 4 Spoke Sport
N60 - Wheel, Aluminum, Painted
N66 - Wheel, Styled Aluminum
N73 - Wheel, Custom Sport Var4 17"
N92 - Cover, Wheel, Bolt-on
N96 - Wheel, 16 X 8 Cast Aluminum
N98 - Wheel, 16 X 8 Cast Aluminum Chrome
PA6 - Wheel, Styled Painted
PW7 - Wheel, 16 X 8 Aluminum Styled
P05 - Wheel, Chrome
QB3 - Wheel, 16 X 7.5 Steel
QCB - Tire, All P235/55R16-96T BW AL2
QEA - Tire, All P215/60R16-94T BW AL2
QFK - Tire, All P275/40R17-93W BW HW4
QFZ - Tire, All P245/50R16 BWAL3
QF6 - Wheel 17 X 9, Aluminum
QII - Tire, All P215/60R16-94H BW AL3
QLC - Tire, All P245/50R16/N BL HW4
TR7 - Headlamps, Control Leveling System, Automatic
T2H - Ornamentation Exterior, Export Unique Requirements
T2J - Ornamentation Interior, Export Unique Requirements
T37 - Lamp, Fog, Deluxe
T39 - Lamp, Turn Signal, Auxiliary
T43 - Spoiler, Rear
T65 - Lamp System, Daytime Running, Export
T72 - Headlamps, LH, Rule of the Road
T78 - Headlamp Control, Delete
T79 - Lamp, Fog Rear
T82 - Headlamp Control, Automatic ON-OFF
T84 - Headlamps, RH Rule of the Road
T85 - Headlamps, LH Rule of the Road
T89 - Lamp, Tail & Stop, Export
T90 - Lamp, Signaling and Marker, Export
T96 - Lamp, Fog
UA6 - Theft Deterrent System
UB3 - Cluster, Instrument, Oil Cool Temp Volts Trip Odom Tach
UC2 - Speedometer, Instrument, Kilo & Miles, Positive Bias
UD4 - Alarm, Vehicle Speed, 120 K/H
UK1 - Frequencies, Japanese
UK2 - Lever, Directional Signal, Includes Multi-Functions
UK3 - Control, Steering Wheel, Accessory
UL0 - Radio, AM/FM Stereo Seek/Scan Auto Rev Music Search Cass Auto-Tone Clock ETR
UL2 - Frequencies, European
UL8 - Frequencies, Saudi Arabian
UM6 - Radio, AM/FM Stereo Seek/Scan Auto Rev Cass Clock ETR
UN0 - Radio, AM/FM Stereo Seek/Scan Compact Disc Auto Tone Clock ETR
UQ0 - Speaker System, 4 Dual Front Door Mounted, Dual STD RGE, Qtr/Shelf
UW3 - Radio, AM/FM Stereo Seek/Scan, Auto Rev Music Search Cass Data System Clock ETR
UZ7 - Speaker System 8, Quad Front Door Mounted, Dual Sail Panel, Dual Rear Hatch Amplifier
U12 - Speedometer, Dual Scale with Kilometer Odometer
U19 - Speedometer, Instrument, Kilo & Miles, Kilo Odometer
U59 - Speaker System 8, Dual Front Door Mounted, Quad Sail Panel, Amplifier
U73 - Antenna, Fixed Radio
U75 - Antenna, Power Radio
VA5 - Language Label, English
VD1 - Provision Options, Europe
VE1 - Provision Options, Japan
VE2 - Protector Source Applied
VG1 - Protector, Underhood Compound, Clear
VG4 - Protector, Undervehicle Compound, Black
VG9 - Protector Wax, Exterior Body
VH5 - Plate Vehicle Identification
VI6 - Fleet Incentive, American Standard
VJ1 - License Plate Rear Mounting Package, Japanese
VK3 - License Plate, Front Mounting Package
VL4 - License Plate, Front Mounting Package, EEC
VL5 - License Plate, Rear Mounting Package, Export
VL6 - License Plate, Front Mounting Package, Japanese
VP6 - Noise Control
VR6 - Hook, Tie-Down, Shipping
VR7 - Hook, Tow, Second, Rear
V12 - Cooling System, Power Steering Fluid
V76 - Hook, Tow
WS6 - Performance Package Special
WX7 - Wiring Provisions
W53 - Entertainment System Option C
W54 - Entertainment System Option D
W55 - Entertainment System Option E
W66 - Merchandised Package, Formula
W68 - Sales Package, Firebird Ground Effects
X10 - Entertainment System, Option L
X20 - Entertainment System, Option M
Y3F - Sales Package, Sport, Appearance Upfitter
Y4A - Exhaust Cat Back
Y4B - Provisions Level II Ultra Performance Suspension
Y4C - Lubricant Engine Oil & Performance
Y4D - Axle Torque Sensing Differential
Y4E - Cooling System Engine Oil
Y4F - Provisions Hurst Shifter
Y4G - Provisions Chrome Wheels
Y4H - Ornamentation Dash Plaque & Key Fobs
Y4J - Covering Floor Front Mats
Y4K - Protector Car Cover
Y4L - Provisions Spoiler
Y81 - Merchandised Package, Firebird
Y82 - Merchandised Package, Firebird, Trans Am
Y84 - Merchandised Package, Firebird Trans Am, GTA
Y87 - Merchandised Package, Performance Enhancement
1R3 - Vehicle Identification Label 1
1R4 - Vehicle Identification Label 2
RPO Code List
P05 - Wheel, Chrome
T43 - Spoiler, Rear
T96 - Lamp, Fog
VP6 - Noise Control
V76 - Hook, Tow
Jul 4, 2005 05:00 PM
DropTop91
22
Aug 8, 2002 10:53 AM
teedoff59
Aug 8, 2002 01:36 AM
