1997 dash pad replacement
Old Sep 27, 2008 | 02:55 PM
shock6906's Avatar
I've got my old dash pad out and now it's time to put the new one in. How do I do this without splitting it in half? Some trick angle to attack it with? All help is appreciated.
Old Sep 27, 2008 | 03:29 PM
Even with the A pillar covers off, you stll have to flex it a little.
Old Sep 27, 2008 | 04:05 PM
shock6906's Avatar
Whew, just got back inside. I ended up having to grit my teeth, close my eyes, and bend it a bit to get it in. Thankfully I did it without busting it.
With the A-pillar covers removed, I found it easiest to put the passenger side corner inside the A-pillar, move the left defrost vent out of the way as far as it'd go, and bend the driver's side of the dash pad around the A-pillar. I swear they could make an install video for the dash pad and call it a horror movie, because that's the scariest thing I've seen in a while.
Old Sep 27, 2008 | 05:20 PM
slowride94z's Avatar
good news,
where did you get yours from?
any thing else I might need to know when I decide to replace mine"that I shattered"?
Old Sep 27, 2008 | 06:42 PM
shock6906's Avatar
Originally Posted by slowride94z
good news,
I picked mine up from the dealership. My stepdad's got a wholesale discount there, so I was able to get it for about the same price as the ones on eBay, but without the risk of it being broken in shipping.
As far as tips on how to install the new one, all I can say is get everything out of the way that you possibly can when you're putting the new one in. Luckily it's got a bit of flex to it, but I was still scared as hell putting it in. Good way to test you blood pressure!
Old Dec 25, 2011 | 12:59 PM
rayline1's Avatar
Re: 1997 dash pad replacement
Hi guys, thanks for all of your post really appreciate reading them before doing a project. I just replaced the dash-pad on my 97Z28. I bought it from autopartscheaper.com it was a OEM exactly like the one that came out. It was $214.95 plus $61.90 for shipping. I took off the T-tops and removed the two screws that held in the A-pillar covers on each side. Removed the A-pillar covers. Removed the old DP. Removed the round post that broke off inside of the holes. Glued the square Velcro pads back in place with fast drying automotive goop. I took the new DP in the house and turned up the heat so it wouldn’t be cold in case I needed to bend it a little but it was already reasonably bendable. I was surprised how easily the new DP went in. I put in the drivers side first because I had more room for my body to maneuver around in the passenger seat, and in it went with very little trouble. Put covers back on and it looks great.
Old Dec 30, 2011 | 04:06 PM
97Z4CZ28's Avatar
Are you referring to the long plastic piece that fits up against front windshield or the front dash piece? Asking cause the piece that I am referring to is the front piece that is from what I read is common to crack, which mine is and I plan to replace soon as well. Anyone got pics? Thanks!
Dave
Old Dec 31, 2011 | 03:20 PM
Sick97SS's Avatar
If your dash isnt cracked too bad you can always glue it and cover with heavy duty grade vinyl. Much cheaper option than paying hundreds for a new dash. It will never crack again!
It's been in my car for about 4-5 years now and still looks like the day I put it in.
Here's some pics of my project.
Dash Pad Fix Page
Old Jan 2, 2012 | 08:24 PM
Asylist's Avatar
Thought about doing the vinyl in my car too, but worried that it would look tacky around the vent area since the vent its molded in to the dash, instead of being able to pop it out to firm the vinyl around the inside edges.
Old Feb 6, 2012 | 07:27 AM
97Z4CZ28's Avatar
You can get a new dash pad from GMPartsdirect.com for under 200! Just throwing that out there cause I have not found anywhere online that can beat GMPartsdirect! Used to be Dal from Van Devere Olds, which he retired in 2007 was best source online.
Old Feb 6, 2012 | 09:25 AM
whitdog54's Avatar
http://ls1tech.com/forums/appearance...brand-new.html
^ill just be repairing and wrapping mine this summer
Jazsun
Dec 29, 2014 12:14 PM
nikko
Dec 2, 2014 03:43 PM
siguy
Nov 27, 2014 10:07 AM
97QuasarBlue3.8
Sep 15, 2002 06:56 PM
