1994 Z28, Fuse blown?? Power windows, Convertable top motor, and radio not working.
I was working on my power windows to test if the motors were bad, or if it was a bad connection somewhere only making it seem as if the motors were bad. I did this by connected the hot wire to one of the other wires to see if the window motor was working ok. It turns out that the window motors are bad as they still went up and down sluggishly and sometimes stopping halfway; however, in the process of testing this all out, I accidentally touched the hot wire to one of the wrong wires. Now my Radio, Power Windows, and convertable top motor(in the trunk of the car) are not receiving power. I believe it has to be a blown fuse somewhere. Does anyone have other ideas, or where to start looking for the fuse?
Thank you.
Thank you.
relay under dash
there is a relay box next to the tunnel on the left of the console if there is no power at the 30 amp breaker then it will be that just replace that and that will solve your problem i have a t top but the radio windows and the convertiable is all at the 30 amp breaker if the relay is bad you wont get power to the 30 amp br. hope that helps
Jul 4, 2005 05:00 PM
94z28jbw
Sep 8, 2002 03:22 PM
