1994 firebird vats problem
Re: 1994 firebird vats problem
Originally Posted by Frank95z
Shoebox on the resistor for the vats disable the ones at radio shack are 1/2 watt is that the right ones. My key measured 9.5k ohms so with the 5% tolerance i'm thinking that the 10 ohm should check out close. Thanks Frank95z
According to the passkey chart http://shbox.com/1/4th_gen_tech2.html#pass_key no resistors were any where near only 10ohms
Also, Shoebox:
If you were to wire in the resistor and have the vats fuel shutoff tuned out, would this effectively stop VATS from being able to not allow you to start the car? Or what else would you need to do?
Well, I got the car started tonight.I used jumper clips on the resister to make a better connection on the bypass and I also bypassed the vats relay(purple and yellow wires). It started right up but only runs for a few seconds then stalls.The security light is still on. Does this sound like the vats module is bad or could it still be something else.Some progress is better then none at all.
My next question is if I do replace the vats module , this will mate to the key and the ignition cylinder, correct.Also as stated in one of the other posts above, do you think the bypass module on ebay will help me resolve my problems without all these other bypasses.Thanks for all the help-John
If you install a new VATS module, it will program itself to the key that you have (assuming the circuitry is complete and it can actually read it). This automatic programming only works one time.
So if i were to install the resistor to bypass the key pallet, and have the fuel cutoff tuned out, the vats would be totally bypassed?
What does bypassing the relay entail?
Hadnt seen that schematic on your site before for whatever reason.
Ill definetly try this, alot easier than messing with a resistor, plus i can have the fuel cutoff tuned out for free.
Yet again, thanks shoebox
edit: Will jumping the yellow and purple wires together make it so the car will start without the clutch pushed in? Or is that function of the theft deterrent relay retained?
If you want to retain the relay and the clutch/transmission lockout ability, do nothing but permanently ground the yellow/black (A1) lead to the relay (don't disconnect or jumper the yellow and purple). That will allow the relay to operate when the key is in the START position, regardless of what the VATS is doing.
I got the Vats bypass module from Ebay, it was like 28 bucks shipped. Three wires simple hookup. The car started right up and stayed running. Thanks again for all the help shoebox.
Now, you are an expert.
