Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
testing fuel injectors
Old Jun 21, 2008 | 07:48 PM
akafred's Avatar
is there any way to test fuel injectors on the car?
if i feel the injectors on my engine with it running 7 of them you can feel them ticking on the 8th one you don't feel anything. also if i unplug that injector it doesn't effect the operation of the engine.. any other injector it starts stumbling.. some worse than others.
i checked it with my ohm meter and it come up 13ohms.
i am guessing that its hosed?
Old Jun 21, 2008 | 11:16 PM
Test any other injectors? 13 is close to the 12 ohms they are supposed to be. Have you checked for power on the pink wire to the injector? Have you used a noid light to see if the PCM is pulsing the injector?
Old Jun 22, 2008 | 08:26 AM
akafred's Avatar
i checked that it was outputting power i dont have a noid light so i cant verify its pulsing.. with the engine running there is 13v at the conector..
i will put my meter on hz and see if its pulsing
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
