SVO 24# injectors?
SVO 24# injectors?
I am a little confused about wich injectors I need to run with my dry nitrous kit? I know I need the svo 24# injectors, but there seem to be two different kinds, The ones with 4 holes in the end and the ones that have a single hole in the end. Wich do I need? I Drove to denver the other day to buy a set of flow mached injectors only to find out he had 7 with 4 holes and 1 with a single hole, so I didnt get them. I need to replace my stock injectors so they dont lock up again @ 90 psi.
Does the ZEX dry kit boost the fuel pressure? Is that why you are looking at the SVO injectors? As long as it is a "pintle" style injector, it won't lock up at the elevated pressures used with most LT1 dry kits. You just need to be sure the "4 hole" injector is a pintle style.
Yup dry zex kit bossting fuel pressure to 80 plus psi. I just won these ijectors off ebay http://cgi.ebay.com/ebaymotors/ws/eB...6070315&rd=1,1 so hopefully these are the ones that wont lock up at high pressure.
autoxr166
Sep 25, 2015 04:21 PM
