Surging at 5000 rpm
Re: Surging at 5000 rpm
Kevin made a typo....
The small black rectangle on the top of the intake manifold, right behind the throttle body is the MAP (manifold absolute pressure) sensor.
The ICM (ignition control module) is just one component of the ignition system. It also includes the coil, the Optispark distributor, the spark plugs and the spark plug wires and coil wire. Any one of those components could break down and cause misfires.
Here's a site the will show you where the components are on an LT1 engine:
4th Gen LT1 F-Body Tech Aids
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
