Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Is stock GM fuel pump good enough for LE2 Setup?
Old Feb 23, 2007 | 11:28 PM
jclark311's Avatar
My heads are out to lloyd, i am going LE2, (heads and cam), NA 97 Ramair lt1 with Non emissions longtubes, 1.6 rr, 52MM TM, and stock MAF. Lloyd says to go with Racetronics Delphi 37lb injectors, so thats what i will do, is the stock fuel pump good enough, or do i have to upgrade?
Old Feb 24, 2007 | 07:17 PM
94/96ZsM6s's Avatar
the stock one should be plenty if your a N/A 350. the injectors should be enough as well, if not adj. pressure regulator. for my N/A 396 i have just a walboro 255lph pump and 30pph injectors and no fuel supply issues.
Old Feb 24, 2007 | 08:20 PM
jclark311's Avatar
I was thinking about going with Delphi 37lb injectors and the stock pump, this way later i can upgrade to a 396 shortblock, with my LE2 heads, and a racetronics pump.
Old Feb 24, 2007 | 08:35 PM
ABA383's Avatar
I know the stock pump and 30lb Accels feed my 383 just fine...
--Alan
Old Feb 25, 2007 | 07:34 AM
2000GTP's Avatar
If your fuel pump is healthy right now, then I would just leave it be.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
