Is stock GM fuel pump good enough for LE2 Setup?
My heads are out to lloyd, i am going LE2, (heads and cam), NA 97 Ramair lt1 with Non emissions longtubes, 1.6 rr, 52MM TM, and stock MAF. Lloyd says to go with Racetronics Delphi 37lb injectors, so thats what i will do, is the stock fuel pump good enough, or do i have to upgrade?
the stock one should be plenty if your a N/A 350. the injectors should be enough as well, if not adj. pressure regulator. for my N/A 396 i have just a walboro 255lph pump and 30pph injectors and no fuel supply issues.
