Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
stock fuel pump replacement??
Old Nov 14, 2007 | 07:20 PM
touch109's Avatar
Exclamation stock fuel pump replacement??
can i just drop in a stock fuel pump to replace a failing stock fuel pump..
would it be easier than gettin the walbro installed..
Old Nov 14, 2007 | 10:38 PM
z28tranz's Avatar
No it wouldn't be easier they are both in tank pumps, you might as well replace it with a walbro that is better than stock!
Old Nov 15, 2007 | 06:58 PM
touch109's Avatar
Exclamation
y cant i just drop in the stock pump from the top without removing the gas tank or making a whole in the tank.
Old Nov 15, 2007 | 08:36 PM
greenmachinedriver's Avatar
there are only 2 ways to get the pump out, drop the tank or cut a hole in your floor. either way it will be no more difficult to install a walbro. its just whichever one you feel like you need.
Old Nov 16, 2007 | 10:20 AM
touch109's Avatar
ok im going to buy the walbro fuel pump do i need to buy anything additional im going to try to install it by cutting a hole on the top on the tank..
Old Nov 16, 2007 | 10:37 AM
mdenz3's Avatar
DON'T CUT THE TANK Cut the floor above the tank or drop it out.
Old Nov 16, 2007 | 10:45 AM
touch109's Avatar
yea thats what i meant.. is it ok the my car is stock..
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
