Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Spark plugs and Wires
Old Jan 14, 2010 | 02:44 PM
camarolover97's Avatar
Hello, Everyone
Im getting ready to get new plugs and wires.
What kind should I get.
also best way to install them my bbk headers are not making it easy
Thanks George
Old Jan 16, 2010 | 11:21 AM
For what is basically a stock engine, I'd recommend the NGK Iridium plugs (TR55-IX). I don't know if there are any limitations with the BBK headers that would require a shorter than normal plug, though.
For wires, a good set of Taylor 7mm resistance wires will work fine. Factory (GM) 7mm wires will work fine too. If you want a bit more insurance with the headers, move up to an 8mm wire, for its thicker insulation (e.g. Taylor Spiro-Pro 8mm). I like the MSD 8.5mm SuperConductors, but they are a bit thick to fit into the stock bracket on the front of the engine. If there are any spots with potential clearance problems to the headers, install the Taylor FireSleeve woven fiberglass shields.
Old Jan 17, 2010 | 06:00 PM
ok thanks alot i appreciate your help
Old Jan 17, 2010 | 06:08 PM
Klypto's Avatar
dont want to highjack , but for cam only motor, tr224/224-112 use same plugs?
Old Jan 17, 2010 | 06:24 PM
Yes. You don't need the colder TR6.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
