Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
smelling fuel
Old Sep 29, 2008 | 08:50 PM
OneBadRedz28's Avatar
smelling fuel
hey everyone i have a 95 z28 and lately when i come to stop lights etc ive been smelling fuel sometimes a lot and sometimes very little. It has a aftermarket fuel pump that was installed previous to my buying the car. I looked at the fuel rail area etc and didnt see anything. Anyone have any ideas on where to look etc. Sorry if i sound dumb but im new to these engines etc. thanks everyone
Old Sep 29, 2008 | 10:01 PM
Angelis83LT's Avatar
did you look at the FPR? when those go you can smell fuel.
Old Sep 30, 2008 | 10:19 AM
EnFuegoZ28's Avatar
Can you smell it when your outside of the car. If it smells strong by the DS rear by the fill door it is probably bad lines to the charcoal EVAP canister or the canister is saturated w/ fuel.
Old Sep 30, 2008 | 10:32 AM
thanks for the advice its usually bad when ive been at a stop light for maybe 15sec or so. it seems to smell a lot more on the drivers side . its weird tho cause the car has to be warmed up etc it seems.
Old Sep 30, 2008 | 10:48 AM
stvski80085's Avatar
It could also be an exhaust leak or loose spark plug if your car is running rich. i had the same problem and it was actually my spark plug was about to fall out.
Old Sep 30, 2008 | 11:25 AM
yea i never thought of that i know my driver side header has a little exhaust leak every now and then and its burin a little rich i can tell.
Old Sep 30, 2008 | 03:21 PM
gwd1995Z28's Avatar
What cause the EVAP cannister to get fuel soaked?
If the fuel seem is from a satuarted charcoal EVAP canister, what can we do to prevent the replacement from being soaked too?
Old Sep 30, 2008 | 06:22 PM
Make sure the purge system is operating correctly. Don't try to fill the tank all the way to the fuel cap level.
AtlasXVIII
Aug 2, 2015 10:29 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
MonoxideChild
Mar 15, 2002 01:40 PM
SNEAKY NEIL
Mar 2, 2002 01:23 PM
ProjectRS
Feb 6, 2002 08:06 PM
