Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Racetronic Fuel Pump on a stock car
Old Aug 1, 2008 | 09:19 PM
JMG97SS's Avatar
I installed a racetronics fuel pump kit when the factory pump went out in my car and lately the car feels alittle flat on power when you first get on the pedel, like alittle bog. Is the fuel pump to much for a car with no real mods, is it make it to rich down low or could the fuel presure regulator be bad?
Old Aug 2, 2008 | 12:11 PM
Should not be a problem. The stock fuel pressure regulator should be able to handle that pump. As long as the system is producing the correct pressure at the rails, its not going to cause the engine to run rich or lean. Best way to find out is to put a fuel pressure gauge on it, and watch how the fuel pressure varies under various driving conditions.
Old Aug 2, 2008 | 04:45 PM
JMG97SS's Avatar
thank you for the reply and help
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
Skull Leader
Aug 10, 2002 11:01 AM
