Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Question about my injector install
Old Sep 9, 2011 | 10:25 PM
ascastil's Avatar
I put some new injectors in today and have a question. The injectors "snapped" into place on the top into the fuel rail. When installing the whole assembly, the injectors seem to be just sitting snug in the manifold. Is this the way its supposed to be? I would assume if it had a snug fit the o ring is then what would make the seal.
Old Sep 9, 2011 | 10:30 PM
Feenix's Avatar
Re: Question about my injector install
If I remember correctly, my svo's popped into place when I put them in the manifold bores. Not as firmly as they snap into place on the rail, but I do recall feeling them seat themselves in the bores.
Old Sep 9, 2011 | 10:47 PM
ascastil's Avatar
Hmmmmmm.....They are racetronix injectors, cant really get them to go any further into the manifold, the rail is bolted down as tight as it will go. I can also spin them around in place. I dunno, maybe the o ring will seal it?
Old Sep 10, 2011 | 06:31 AM
It's normal to be able to twist the injectors in place, and even have them slide up an down a bit (if retainer clips aren't used). They aren't supposed to be "crushed" into the holes in the manifold. The bottom o-ring only has to seal against the manifold vacuum (less than 30"Hg), not the fuel pressure. It's the upper o-ring that seals again the fuel pressure.
Are you using the clips to hold them in the rail?
Old Sep 10, 2011 | 10:32 AM
ascastil's Avatar
no, not using the clips, as long as you verify to me that the o ring makes the seal on the bottom, that makes me feel better. i read the clips were only used to help during install and werent necessary, plus they didnt fit over new injectors. ill have to wait for my new fuel pump to get in and for my pcm to get back from getting flashed to test for any leaks. thanks
Noenav
Mar 1, 2019 07:38 AM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
