Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Power for universal coil
Old Apr 11, 2012 | 10:11 PM
Bigjaycass's Avatar
I am switching my 95 Z28 to a carb and hei distributor. I wanted to know if anyone know a good place to splice into to get power when the keep is on? Thanks for any help.
Old Apr 12, 2012 | 11:04 AM
bobdec's Avatar
Re: Power for universal coil
You probably want a "+12 Hot in run, test or start" line to feed the distributor. Since you will be pulling the old harness and PCM out the most reliable spot would be to get the +12 volts from the under hood fuse block. Fuses 9 & 10 7.5 amp each feed the injectors which you will no longer use. So you could get into the under hood panel and use one of then to feed the HEI. Or just pull a pink wire out of the injector harnesses left or right as it comes from the IP box fuses 9 or 10. Then when you remove the injector harness run the pink wire to the HEI.
Old Apr 12, 2012 | 11:50 AM
Bigjaycass's Avatar
Sorry, I meant when the key is on, not keep on.
Old Apr 12, 2012 | 04:34 PM
bobdec's Avatar
Correct... Hot in run is with key on only, start is when car is cranking and test is when key is turned off to on to test indicators, line is not active with key in Accy mode. That is when you would want the distributor/ignition activated. I agree "Always Hot' is directly connected to the battery, via a fuse and you don't want that.
Victor Lamb
Aug 26, 2017 02:52 PM
XtremeLt1
Sep 13, 2002 08:50 PM
kandied91z
Aug 6, 2002 01:18 AM
