Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Optispark adapter question
Old Jan 15, 2012 | 04:25 PM
wbacall's Avatar
I am installing a 1995 engine with vented opti in my 1994 Z28 with non vented opti. The vented optispark harness connector does not quite fit the cars original harness plug, do I just move the pins to the original connector in the same position?
Thank you!
Old Jan 15, 2012 | 06:45 PM
Re: Optispark adapter question
You buy a "short" Opti harness with the correct longer plug on the end. The short harness starts at the gray 4-pin connector on the bracket on the passenger side of the intake manifold:
http://shbox.com/1/evap_sol.jpg
I believe EFIConnection sells the conversion harness pretty cheap (compared to the cost of a GM part).
EFI Connection, LLC - Engine Storage and Shipping
Old Jan 15, 2012 | 09:13 PM
wbacall's Avatar
Thanks! I ordered the connector.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
nosliw
Feb 7, 2015 01:30 PM
Injuneer
Dec 15, 2014 09:36 AM
