Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
ok i got the msd digital 6
Old Jan 31, 2007 | 02:22 PM
93camarochrisz28's Avatar
what are a few of the other things i shoud get to have this work the best it can
Old Jan 31, 2007 | 02:40 PM
2000GTP's Avatar
Nothing you really need other then the coil harness to simplify the installation.
Old Jan 31, 2007 | 03:50 PM
so just the coil what coil should i get
Old Jan 31, 2007 | 04:56 PM
mrmint69's Avatar
There is a gm plug that makes it a plug and play with no splicing or anything. It is on there web site. I also had to buy some sprinkler drip line to hook up my vacuum line for the boost control if you have that.
Old Jan 31, 2007 | 05:29 PM
Guido67SS's Avatar
I've been through three of these boxes. Nice but don't wear well if abused. Make sure you mount the box with the shock absorbers, away from heat and make sure your hot and ground are rock solid and direct. I ran my hot straight from the battery terminal, with a good ground. By good I mean I took a wire wheel to the frame until I got to bare metal. Make sure you have premium set of plug wires and never turn the engine over without the plug wires hooked to the plugs. Read the directions, red flashing light means low voltage or bad connection. If not abused, a nice unit.
Old Jan 31, 2007 | 06:51 PM
2000GTP's Avatar
I was referring to the wiring harness that connects the box to the ignition coil. You could replace the coil as well with an MSD unit if you wish, but it won't provide you any real benefits unless your stocker is worn out.
Old Jan 31, 2007 | 08:13 PM
ok frist off i would like to say thanks for all the help but will the stock distributor be fine or should i get the msd one to match or is the a better one out there that i should get
Old Feb 1, 2007 | 12:28 PM
2000GTP's Avatar
Just stick with the stock distributor and if you do change it, save the money and buy another Delco replacement.
Old Feb 4, 2007 | 08:56 AM
why is that the delco just as good what about the coil the old stocker will do fine ?
Old Feb 4, 2007 | 11:30 AM
2000GTP's Avatar
The stock Delco stuff works just as good as is a fair amount cheaper. If you do a search, you will find old posts where the MSD opti doesn't have the cleanest track record.
Old Feb 4, 2007 | 11:31 AM
Guido67SS's Avatar
Unless the distributor is broken buying a new MSD distributor will not be an advantage. I am not sure of your application. Does your present distributor have mechanical advance or is it computer controlled? Do you have a high stall converter? If you do then the advance does not matter.
What are you tryiing to do? How fast? What is your goal?
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
