No Fire, Need Quick Help
I have a 95 z28 that has been having starting issues. Every once in a while when I turn the key to crank the car there would be no response and no dash lights. Yesterday it left me stranded at work which is 45 min. away from home. After reading the forums last night I decided to replace the ignition switch on my lunch break today. The car now turns over as normal and the fuel pump is coming on but I'm not getting any fire to the plugs. I ran out of time before I could check to see if I have any fire from the coil but I’m pretty sure I don't. I do have an MSD box (6al) hooked up. Does any one have any ideas what I should be checking for? I get off in an hour and will be off until Tuesday and really need to get my car home today. Is there any way to check the module?
68camaroboltz
Oct 5, 2015 11:56 PM
