New Racetronix install now will not run
Re: New Racetronix install now will not run
Yes, I glued the bucket and probably did an excellent job. LOL. Will probably be harder to seperate than factory. Would a parts house (Autozone or O'Reilly) fp regulator be ok or should I go with dealer item? Dealer does not have it in stock, but parts house does. Contacted Racetronix and they sent me to their forum to register. Think I will have any luck in replacing it with them? If not, may just order a new one.
Well could not see it the several other times that I took the pump out, but I found a small hole in the Teflon fuel line. Got a new one coming and hopefully that is all that was wrong. I swear that I looked and looked at that line and even blew into it trying to see if it was the source.
They are sending me a new hose and it should be here Monday. Glad I was able to find it and hopefully will fix my issue. I appreciate all your help and sticking with me.
Got the new hose from Racetronix on. Primed up pump and reads 40psi let it sit and pressure held just right. Looks like it was only the hose and was busted due to being folded over for packaging.
ezcheeze15
Aug 26, 2002 01:28 PM
