Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need helpcar wont start PLEASE
Old Mar 12, 2016 | 06:09 PM
OutlawPerforman's Avatar
Having a major problem with my car it spins over but does not want to start or even sputter to start.
What happen was I ran out of gas luckly at home and had enough to make it to gas station however it died and had to coast into a gas station,
I immediately filled her up gas 93 and right away no luck.
I tried starter fluid which didn't help so it was towed home.
Tried water dissipate, octane booster, heet, 108 octane and nothing works
Anybody have any idea where to start im hopping its a bad sensor like a (MAP) I'm really stack and need any help
2002 Camaro Z28
Old Mar 12, 2016 | 07:56 PM
Re: Need helpcar wont start PLEASE
Have you checked the fuel pressure?
Have you scanned it for codes?
Have you checked for spark at several spark plugs?
Old Mar 12, 2016 | 07:59 PM
Strongly prefer that you post a topic on only one forum, not three.
Let's keep this thread open until we know the answers to the above. Then I can move it to another forum if necessary.
Old Mar 12, 2016 | 10:14 PM
Fatdog2's Avatar
The fuel pump needs gas to keep it cool.It can overheat and die with no gas.As Injuneer said please do a fuel pressure check before anything else.Next I would change the fuel filter as it can suck up all the crap at the bottom of the tank and clog up the filter.Scan for codes.Hope this helps.
anmar A
May 2, 2015 06:59 PM
Drtryder
Apr 22, 2015 04:17 PM
redzed
Aug 28, 2002 11:30 AM
Desolate_Flux
Jul 23, 2002 08:24 PM
