Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need bigger injectors. How are these
Old Oct 1, 2008 | 09:32 AM
cmking26's Avatar
Im doing heads and cam this winter should be just over 400rwhp. I am looking at getting 36lb Bosch fuel injectors I found a nice used set for $120. They are nickel plated and white in color. Bosch style Design III top feed injector, blue tops, 378cc /min flow rate. Will these work?
Old Oct 26, 2008 | 03:06 PM
CreatiVe2's Avatar
wouldnt need much above 32 Lb for this application.
heres something also to keep in mind about Injector properties
http://www.youtube.com/watch?v=7oTirEZNRw8
http://www.youtube.com/watch?v=NIz5c9MLCls
Old Oct 26, 2008 | 03:45 PM
cmking26's Avatar
The Bosch ones seemed to do fairly well in both tests. My tuner told me to get 36lb'ers but I could probably get by with 30's just depends which I can find cheaper.
Old Oct 26, 2008 | 03:56 PM
CreatiVe2's Avatar
the bb302 are pretty low $ on ebay
Old Oct 26, 2008 | 06:08 PM
Originally Posted by cmking26
....My tuner told me to get 36lb'ers but I could probably get by with 30's just depends which I can find cheaper.
Listen to your tuner. You would be foolish to try and run 30# injectors at 400rwHP. Injector size is determined by flywheel HP. With your A4, you will probably be making 475-500HP at the flywheel. A rough guideline is to multiply the flywheel HP X 0.07 to get the minimum injector size.
0.07 x 500 = 35 #/HR
What happens if your engine makes more than you anticipate? What happens on a cool, dry day with sub-sea level air conditions? Engine makes more HP than the STD or SAE measured HP, and your injectors have to work even harder. I'd consider 42's. Its not about "cheaper".... its about choosing an injector size that will meet your engine's needs.
Old Oct 26, 2008 | 07:24 PM
cmking26's Avatar
Yeah I will definitely get at least 36's I've found some on ebay fairly inexpensive.
Old Oct 27, 2008 | 10:42 PM
Green96Z's Avatar
I went with 37# Racetronix injectors for my LE2 swap. That way I have plenty of injector for further down the road.
Old Nov 13, 2008 | 03:32 PM
wrd1972's Avatar
Same here
GREEN3112
Feb 10, 2019 09:19 PM
magman
Apr 15, 2016 03:08 AM
Hal Fisher
Sep 30, 2015 09:03 PM
autoxr166
Sep 25, 2015 04:21 PM
95craz28
11
Sep 12, 2015 07:47 AM
