Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
My idle is constantly changing. HELP!
Old Oct 26, 2010 | 01:33 PM
CTK1's Avatar
Hi guys. I have a 1969 SS that had a 355 in it. For the last couple of years I have had issues with the idle constantly changing. I would talke it for a ride, and come to a stoplight, and it would either idle fine, be idling faster, or idle very slow and stall out. However, it would never do one of these things constantly. I had the carb rebuilt twice, and installed a new intake with new intake gastkets and the problem persisted.
Fastforward to this spring, In May my 355 let go. It was a total loss. I replaced it with a professionally built 383 stroker. Other then the block, it is completely new from top to bottom, including a new carb and a new fuel pump. It is a late 80's block with a one piece seal. Eagle forged crank, rods, and sealed power forged pistons. Dart Pro 1 Platinum aluminum heads, Edelbrock Performer RPM AIRGAP intake, etc. Unfortunately I am still having the same issue with the idle constantly changing. Do you guys have any ideas?
The car has the original fuel lines still on it. I was thinking maybe there could be a little pinhole in it, and that may be causing it to suck air and change the idle depending on how the car is sitting or something along those lines. Any help would be appreciated. Its really getting aggrivating. I love the sound of the cam when it holds its idle, but that typically doesn't last long.
PopoFormula
Oct 12, 2015 04:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tdigger9899
Sep 7, 2015 10:56 AM
