Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Multiple Misfires
Old Oct 1, 2010 | 03:45 PM
Sunsetmaro's Avatar
Multiple Misfires
Well. As the titel says. The car has multiple misfires. I have a volt meter and suspect it being coil packs. The car starts fine but after like 3 minutes it will begin to misfire. Driving it, you can get past the bad idle and power through and the car will run fine... I have a volt meter and want to know if anyone has a clue on what it should read from the pack to wire, meaning I want to take the spark plug wire off and test to see what the coil pack is putting out... Anything would help. Thanks
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
