Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
MSD Opti Timing screw??
Old May 27, 2008 | 06:19 AM
978Racing's Avatar
My new MSD opti has the adjustable timing screw. Which way advances the timing?? Turning it in or backing it out??
93Z CC305-8,Fastchip tune,2400 stall,shift kit, Hammer shifter,MSD opti,MSD digital 6,SVO 24lb injectors,brake conversion,3.73 posi,Alum driveshaft,
Old May 27, 2008 | 06:43 AM
rcantrellz28's Avatar
Turning it clockwise will retard timing , while ccw will advance timing.
Old May 28, 2008 | 04:54 AM
978Racing's Avatar
Thank you
Old May 29, 2008 | 09:34 PM
my96z's Avatar
Good luck getting it to work though. Mine runs kind of flat since installing mine. I started out at the stock setting and backed it out and it hasnt helped much.
Let us know what happens with yours.
Jeff
Old May 31, 2008 | 10:35 AM
Check threads by "The Engineer". He has identified a problem with the internals NOT actually moving when you turn the timing screw on the MSD Opti.
Old Jun 1, 2008 | 09:56 PM
978Racing's Avatar
Jeff
Mine makes a small ticking sound when you move the screw, so something is happening. I have not had a chance to test drive it yet. I work alot and this is not my daily driver. I'll report back if anything noteworthy occurs, when I take it for a spin. Idle sounds strong.
Old Jun 8, 2008 | 08:35 PM
978Racing's Avatar
I have taken the car out for a few runs. It doesn't feel quite as strong as before. Especially off the line tire spin. With my cheap tires they would really burn, fishtail through first and second. (Great fun) And that was not even floored. Now it doesn't spin as much and is harder to do. It may also be because it is 95 degrees down here in florida and a month ago it was not, but that that may be be only part of it. I did think of an interesting idea though. HAS ANYONE TRIED TO ADD A FEW DEGREES ADVANCE TO THE RE-TUNE??? (93 Z Speed density OBD I) I just changed to bigger injectors and need to send my prom to Fastchip for a re-tune, Can I have them add a few more degrees advance to the re-tune?? I think the car is only a few degrees retarded from where I was with the gm opti. And thats with the MSD timing screw backed all the way out.
Appreciate any and all advice!! Also Injineer, I looked for you thread and couldn't locate it?
Old Jun 8, 2008 | 11:08 PM
Picked up with a search on "MSD Opti Screw", posts by "The Engineer":
https://www.camaroz28.com/forums/sho...MSD+Opti+screw
Old Jun 9, 2008 | 10:26 AM
978Racing's Avatar
[QUOTE=Injuneer;5416674]Picked up with a search on "MSD Opti Screw", posts by "The Engineer":
https://www.camaroz28.com/forums/sho...MSD+Opti+screw[/QUOTE
Thanks Injuneer. What a pain that I have to jump thru hoops to make this thing work.
Old Jun 27, 2008 | 10:50 AM
CGrant's Avatar
I was about to order a msd opti until i read this thread, i am glad i did.
Makes me wonder why msd just doesnt eliminate that screw and be done with it, i wouldnt have an issue with it...if it worked.
I am taking my car apart this weekend as my car wont start, i have spark at the coil but nothing at the plugs. I am thinking my rotor got ripped apart of the cap is fried?
I just hope i dont have to replace the entire distibutor?
If entire opti is bad what would you guys recommend i buy?
I see accell has one or should i just get the stock replacement opti from gm?
Old Jun 29, 2008 | 06:18 PM
978Racing's Avatar
Honestly if I had to do this over I would just get an GM opti. My original went 110.000 miles and the car ran like a banshee. I have sent my computer prom to Ed Wright (Fastchip) for a re-tune. I needed the re-tune for bigger injectors anyway, so I asked him to advance the timing a few degrees. Well see what happens. I'll post the results.
Old Jul 7, 2008 | 07:31 PM
978Racing's Avatar
I have been driving the car for a week with no issues!! Having Ed Wright (fastchip) add additional timing to compensate for the MSD Opti is the way to go!! The car has its off the line snap again, and really more power everywhere else too. Highly recommend this idea!!
93 Camaro 5.7, cc 305, beehive springs, msd digital 6, msd opti, Tuned by Ed Wright (Fastchip), 24# ford racing injectors, shift kit, 2400 Stall, B & M Hammer shifter, All 4 wheel LS1 Brake upgrade, Grant steering wheel, Aluminum driveshaft, subframe connectors, 3.73 posi,
Old Jul 7, 2008 | 07:36 PM
Accel has problems, too.
Old Jul 12, 2008 | 08:12 PM
my96z's Avatar
Well I made some headway with mine.
I decided to turn the screw a few more turns out, only this time the car was running. I started to turn it and once I got a full revolution it idled faster. Wow, I now know it is doing somthing. It seemed as though the computer turned the idle back down so I turn it once more and it idles up again and once more it settles down.
I take it out on the road and I have alot more snap back and its alot better all around than before. No longer feels sluggish. I am wondering if making the adjustments with the engine running is making a difference. Maybe with the vibrations and everything it helped. I dont know for sure but I am glad my car runs a hell of alot better. Although it must be 7 turns out from the bottom.
Old Jul 13, 2008 | 06:26 AM
978Racing's Avatar
I'm glad you could get yours dialed in!!
