Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
MSD Coil
Old Sep 21, 2007 | 05:10 AM
93BlackTA's Avatar
MSD Coil
I have a MSD Blaster coil on my car and i noticed that it moves a little in the bracket....is this coil supposed to be grounded directly through the coil - bracket or through the wiring?
Old Oct 5, 2007 | 11:43 PM
JooneJune's Avatar
I would suppose the wiring. Mine also moves a little in its bracket.
Old Nov 16, 2007 | 09:01 PM
stopthatman's Avatar
the yellow Accel coil is better and doesn't move
Old Apr 9, 2008 | 10:07 PM
Steve in Seattle's Avatar
couldn't tell ya about the loose issue (in 96-97 designs, you need to drill out 2 rivets on the mounting bracket and tehn bolt the new coil in place... if it's loose just tighten it)... I dont' have a 93.
I just ditched my new MSD coil though for the GM unit... finally revs clean to 7000... no issues like the high rpm miss I was getting with the MSD.
On a stock or bolt-on engine I doubt there's any difference between the MSD and GM unit... at high compression or boost I'd be wary of using the MSD.
No experience with the Accell unit yet.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
Pwilson59
Sep 3, 2015 08:47 PM
canuck94z28
Aug 19, 2015 05:50 PM
