Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ltcc & Msd 6al
Old May 30, 2007 | 09:34 PM
383TransAm's Avatar
Question Ltcc & Msd 6al
Can I use an MSD 6AL with a LTCC setup on my 93 TA?
Old May 31, 2007 | 12:46 PM
Ram Air 383's Avatar
No, there are no MSD ignitions that are compatible with the LSx coil setup.
Old May 31, 2007 | 06:16 PM
But MSD does sell a multiple spark LS1 replacement coil..... pricey though. About $90 each x 8 = $720.
http://www.msdignition.com/coil_blaster_19_8245.htm
I've seen the LS1 coils support 1,350HP in direct fire on a Dart block SBC 383 running 20+ # of Vortech boost. Not sure why you need an MSD replacement.
Old May 31, 2007 | 09:16 PM
383TransAm's Avatar
Thanks.
Is the spark from the MSD better than a single coil per cylinder setup?
I have the truck coils.
Old Jun 1, 2007 | 12:59 PM
"Better" in what respect? The 8 individual coils allows 8X the dwell time to build up charge in the coils. I figure if they can fire my setup with a 300-shot of nitrous, the stockers can handle whatever you throw at them, without the need for any enhancement.
Old Jun 1, 2007 | 02:47 PM
383TransAm's Avatar
Well I just put my MSD in my car a year ago and I don't know if I wan to tear it out?
Basicaly I can get better performance with the 8 coil packs, right?
Old Jun 1, 2007 | 05:14 PM
My original setup was the stock ignition with an MSD-6A box. I eventually replaced it with an Electromotive SDI/Opti-Eliminator, with the 4-coil setup (designed by the same guy that designed the Delteq). With the stroker, I switched to the 8 LS1 coils driven off a MoTeC M48Pro ECU and their IEX 8-channel ignition driver. I copied that setup from a buddy of mine, with a 97 30th SS convertible. He eventually took the car to 1,350HP running low 8's in a 3,500# car. He used the 8 LS1-style coil setup.... Dart Iron Eagle 383 with 20+# of Vortech boost. The only thing he did different with the 1,350HP setup was go to a 16V electrical system.
Old Jun 1, 2007 | 05:41 PM
MEAN LT1's Avatar
Fred, You dont drive your car much do you?. Everytime you post a picture its always like 3-4 years ago.
Old Jun 1, 2007 | 06:03 PM
383TransAm's Avatar
No he just don't change anything
Well my car is a Weekend player so I won't get that crazy
Thanks for the help, if I can pick up a LTCC setup I may change??
Old Jun 2, 2007 | 12:05 AM
That's not my car... it was George Baxter's 30th SS. He sold it in 2004, so I don't have much in the way of new pictures . I have digital photos of my car going back to the 90's, and if they are useful in explaining something to somebody, I can't see any point in not using them.
On the other hand, my car spends most of its time in the garage, due to a job that consumes 6 long days every week.
Old Jun 4, 2007 | 02:08 PM
joe-96z1le's Avatar
I recently converted to an LTCC w/ the stock GM LS coils. Works great. The couple of shops I spoke to said that the stock style system has
plenty of spark. As Fred stated, no need for high output coils.
Save your dollars.
Old Jun 4, 2007 | 04:20 PM
383TransAm's Avatar
Thanks will do.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
