Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LT1 plug wires! i finally found the trick! hope this helps!
Old Oct 18, 2011 | 01:41 PM
nintythreeZ28's Avatar
i put longtubes on my 93z and went through 2 sets of plug wires before i found the trick. stock ones of course my car ate through them in 15 minutes. that was expected. i bumped it up to morosso 8mm plug wires and just routed them slightly different. those lasted about a week. then i finally got smart and ordered some heat shield boots from jegs and slipped them over some msd8.5mm wires. this is what i came up with.
these are the heat boots from jegs.
the tricky part came at the #6 cyl. on teh passenger side ( i believe it was number 6... third one back ) i had to route this wire under the motor mount because the heat boots do not like to bend. this is why i couldnt really do it any other way. if anyone really wants a pic of how i routed them please tell me. i dont want anyone to go through the same thing i did.-
remember your not going to have much room to work with. this is the only way that i could find to work without going to OTVC.
also i can send more detailed pics of how i routed the wires. just ask.
Old Mar 29, 2012 | 09:16 PM
lt1le2's Avatar
Can u please send me some more pics and info I will be doing this weekend I have pacesetter mid headers though I go through wires like crazy.
Sent from my DROID RAZR using Tapatalk
Old Mar 31, 2012 | 11:16 AM
Re: LT1 plug wires! i finally found the trick! hope this helps!
You might want to try an e-mail to "nintythreez28". He has not been active on the site for more than 2 weeks.
Old Apr 5, 2012 | 09:06 PM
omega552003's Avatar
I used a ziptie to hold the plug wires close to the block havn't burned one yet
Old Apr 5, 2012 | 09:27 PM
greenformula94's Avatar
Yup lol like magic
Old Apr 5, 2012 | 09:28 PM
sounds like you must have 200$ into spark plug wires, that sux man lol
Old Nov 8, 2012 | 12:47 PM
im so sorry man i was off for a while. couldnt get my password set. had a big problem with that. if you still need help im here but its been a while and i appoligize!
Old Nov 15, 2012 | 05:10 PM
Kevin Blown 95 TA's Avatar
I hope this does the trick for you.
First time I ever built an engine, I made a custom set of 10mm plug wires for it, then watched with horror when I lit off the engine for the first time and two of them went up in flames from glowing headers. Yup, you need fiberglass socks on our cars, and tie wraps to keep them in towards the engine block. I guess, some things, you just get to learn the hard way
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
