Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
long start on 98 z28
Old Aug 5, 2011 | 05:42 PM
greenhaze928's Avatar
well i have a 98 z28 6spd, and its got a problem on start up,,, you have to crank it for awhile, seems like the fuel bleeds off when it stays parked for awhile..cuz i can get in it start it up let it run for a bit, shut it down and crank it again and it will fire up..so i am leaning towards the fuel pressure regulator..havent ran any fp tests yet, dnt have the gauges or any of that at the moment....so my question is what should the pressure be at key on before cranking, and how long should the pressure hold? Also where can i or do i find the fuel pressure regulator at? Im fairly new to the ls1 so plz bare with me!
Old Aug 7, 2011 | 07:36 PM
Re: long start on 98 z28
22 views n no one has any input
Old Aug 7, 2011 | 08:20 PM
RealDealZ28's Avatar
I've got a '93 Corvette (LT1) that has the same problem. It sometimes wants to crank over for several seconds before it will finally fire. Like you said, it's almost like the fuel bleeds back as the car is sitting.
Old Aug 8, 2011 | 02:22 PM
bobdec's Avatar
I can answer Realdeal however I looked at the OP and I do not know enough about the LS engines to answer the question. In the LT1 majority of pressure leak-down is caused by the check valve in the fuel pump. Other causes can be leaking injector that may show as a rich black smoke start, but not always. The regulator leaking fuel through the vacuum line to the intake, you can visually look or smell that by pulling and inspecting the vacuum line. Or the regulator could not be holding pressure after sitting a while.
My car holds pressure overnight and even longer. here is where the reg is on my car , ref shbox.com http://shbox.com/1/fp_reg.jpg
Old Aug 10, 2011 | 06:55 PM
thanks realdeal and bobdec,, im leaning towards fuel pressure regulator, cause i am not getting any smoke once it fires or anything like that!! its a tough one, but id like to get the problem sorted lol!!
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
