Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
lg4 305 computer to hei non computer swap.
Old Apr 28, 2012 | 12:01 PM
daytonablackZ28's Avatar
I got a question that no one seems to be able to help me with. I have a 1986 LG4 305 computer controlled engine in a 79 camaro. I put in a hei Msd streetfire distributor. Since the motor has its timing tab at the top, what base timing should I start at?. The motor is bone stock inside wither the usual headers, 4bbl, intake upgrades. Any clue on how much timing a stock LG4 1986 305 from a firebird can take WITHOUT the computer controlling the timing?
Thanks guys.
Old May 7, 2019 | 11:38 PM
Dave Traveler's Avatar
Re: lg4 305 computer to hei non computer swap.
I'm swapping a non OBD EGI into an 84 305 Z . Not sure if i need to leave the old module plugged in or leave it out. When I try it ill let u know what I find out.
Old May 11, 2019 | 10:35 AM
update. Factory timing with out the OBD seems to work just fine. Mechanical +vacuum advance would be around 60 total advance. I would say push it up until it starts pinging then back off 5 degrees to swag it.
daytonablackZ28
3rd Gen / L98 Engine Tech
May 6, 2012 03:50 PM
sekou7x
Jan 24, 2011 07:06 AM
89 Iroc conv
Mar 12, 2007 11:40 PM
masiroc566
Apr 21, 2005 08:03 PM
anthony714
Jan 26, 2005 01:06 PM
