Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
jumping RPM
Old 05-13-2015, 10:23 AM
  #16
blac94Z's Avatar
Re: jumping RPM
ok on my lunch break I will run home and see if u can get the files off my computer and upload them
and theres no air pump on my car and there is a fuse there in the fuse slot
and yeah it was to rent so im just going to purchase my own
blac94Z is offline
Old 05-13-2015, 12:09 PM
  #17
blac94Z's Avatar
Re: jumping RPM
with key on engine off am I suppose to hear my fuel pump come on and go off and then 10-15 sec later prime again in a continuous loop ?
blac94Z is offline
Old 05-13-2015, 03:32 PM
  #18
blac94Z's Avatar
Re: jumping RPM
You do realize that the code for the AIR pump is causing your radiator fans to run all the time? All you need to do is put a good fuse in the circuit. If the fuse continues to blow, unplug the pump, then replace the fuse, leaving pump unplugged = no code.
thank you for this comment made me think about a fuse i put in the fan slot a couple
days after the 100 octane now i took the fuse out from under the hood
the fan fuse and the car is back to normal now so now I see I may have a
wiring problem i think
blac94Z is offline
Old 05-13-2015, 04:41 PM
  #19
Re: jumping RPM
No, turn key to "run" - pump should prime for 2 seconds, and stop, never to run again, until you try and start the engine. The PCM will not allow the fuel pump to run unless it is getting the cam position signals from the Opti, and it can't get those if the engine is not rotating (cranking or running).
Injuneer is offline
Old 05-13-2015, 04:50 PM
  #20
blac94Z's Avatar
Re: jumping RPM
yea there is some type of wiring problem with the fan fuse and the pcm bc if I put a fuise in the slot my car starts to run and act funny but when I take it out I have to straight wire the fans to run but my car runs normal with no fuse in fans slot
blac94Z is offline
KYWes
06-14-2022 06:52 AM
98-LS1Z28
09-08-2015 03:12 PM
AtlasXVIII
08-24-2015 11:41 PM
jerrysims71
08-15-2015 12:47 PM
RallyRed701/2
07-20-2015 11:18 AM
Quick Reply: jumping RPM
