Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Intake Manifold Guide Pins
Old Mar 1, 2020 | 07:21 AM
1994-LT1-Eric's Avatar
When R&Ring the intake manifold, what did you use as guide pins to help settle in intake back into the vehicle without disturbing the RTV in the front and rear?
I've read about this but never seen a picture of it or anything specific that works well for re-seating the intake.
Thanks,
Old Mar 1, 2020 | 08:08 AM
Germansheperd's Avatar
Re: Intake Manifold Guide Pins
Real thin dowel rod maybe? Not a lot of room in the back to lift over a dowel tho.
Old Mar 1, 2020 | 08:22 AM
DrewHMS97SS's Avatar
I bought a couple of bolts from Home Depot and cut the heads off. I have heard of using a dowel as well, but I wanted zero play.
Old Mar 1, 2020 | 09:41 AM
3/8”-16 threaded rod or studs.....
from Shoebox
http://shbox.com/ci/ci296.jpg
Old Mar 1, 2020 | 02:41 PM
Thanks! How many did you all use, the 4 corners?
Old Mar 1, 2020 | 04:11 PM
Look at Shoebox's photo - you only need two. They can’t be real thin because that would allow the manifold to slide as it contacted/compressed the sealant.
Old Mar 1, 2020 | 04:52 PM
I got it now thanks, I looked at it closer and see which ones need threaded rod.
Old Mar 1, 2020 | 06:29 PM
4 also would not work because of the angle.
Old Mar 2, 2020 | 07:07 AM
Ok, thanks for the heads up. You have an RTV preference?
Old Mar 2, 2020 | 07:39 AM
Ultra black or the right stuff.
make sure to follow the rtv instructions:
Assemble wet, only tighten the bolts hand tight, wait an hour.
Torque the bolts in 2 passes: http://shbox.com/ci/intake_sequence.jpg
Allow a full 24 hours to cure.
Old Mar 2, 2020 | 10:39 AM
Right on, will do.
lt1le2
Parts Wanted
Oct 1, 2010 11:05 PM
millerlt3
Jan 13, 2007 11:21 PM
Heatmaker
Jun 12, 2006 07:39 PM
rondav WS6
Apr 22, 2006 04:06 PM
speed_demon24
Jul 30, 2004 11:48 AM
